Unmatched technology for unparalleled results
Our UX Series High-Speed Mills are designed to meet the evolving demands of industries where precision is paramount. With cutting-edge technology and a commitment to quality, our HSM solutions deliver exceptional performance for complex and high-precision machining needs.
Accuracy you can count on
Say goodbye to unreliable ball screw mechanisms. Our rigid linear motor technology ensures unparalleled precision, even under continuous, heavy-duty operation. The UX Series ensures long-term positioning accuracy, minimizing downtime and maximizing productivity.
All-in-one functionality
Why crowd your shop floor with multiple machines when you can have just one? The UX Series integrates jig grinding and graphite handling within a single high-speed milling machine to achieve exceptional surface finishes and intricate geometries without the hassle of multiple setups.
Real-time part monitoring
Maintain the highest levels of accuracy throughout your process with our built-in NC measurement system. This advanced feature ensures precise machining with continuous 3D part monitoring and real-time automated process adjustments.
See the power of high-speed milling.
The most advanced high-speed mills yet
Sodick High-Speed Mills
Other Machine Tools
Motor Technology
Rigid Linear Motor (No wear, high accuracy)
Conventional Servo Motor (Wear over time)
Jig Grinding
Integrated
Requires separate machine
Graphite Handling
Integrated
Hard Milling
Integrated
Part Inspection
Equipped with NC Measure 3D part monitoring
The ultimate electrode machining duo
UX high-speed mill + ALG sinker
The UX High-Speed Milling Center allows Sinker EDM operations to cut costs and maximize precision by developing high-performance electrodes in-house.
Aerospace components
From turbine blades to airframe structures, our High-Speed Mill technology ensures the precision needed for critical aerospace components.
Mold and die creation
Achieve complex geometries and superior surface finishes for injection molds, die casting, and more.
Medical implants
When every micron matters, the UX Series delivers. With our advanced machine technology, you can produce medical implants like hip and knee replacements with ultimate precision.
Para todas sus necesidades de fabricación, póngase en contacto con uno de nuestros expertos hoy mismo y obtenga más información sobre las soluciones más adecuadas para usted.
DON’T GET LEFT IN THE DUST!
Enhance your Sinker’s accuracy by producing high-performance electrodes in-house.
Only with the NEW UX High-Speed Mill
(graphite handling option available).
Get a Rapid Quote
HSM – Rapid Quote
"*" indica los campos obligatorios
