Wire EDM has been around since the 1960s, and for the first few decades, non-submerged machining was simply how it was done. The workpiece sat above the fluid line, and two nozzles, one above, one below, sprayed deionized deionized water around the wire to create the dielectric environment needed to cut. It was the only option available, so operators learned to work with it, quirks and all.
Things started to change in the 1980s and 1990s as submerged machining technology matured. Manufacturers began developing tanks that could fully immerse the workpiece, surrounding the entire cut zone in dielectric fluid. The performance advantages were immediately obvious: faster cutting, more stable sparks, less wire breakage, better surface finishes. Shops that made the switch didn’t go back.
Today, non-submerged wire EDM is largely a relic of the past. The last major manufacturer of dedicated non-submerged machines exited the market years ago. Modern machines are built around submerged operation — and for good reason. This article breaks down exactly why submerged machining won out, how the two methods compare head-to-head, and how dielectric oil takes submerged performance into territory that deionized water simply can’t reach.
Why Non-Submerged Machining Became Obsolete
To appreciate the advantages of submerged machining, it helps to understand what operators were actually dealing with on non-submerged machines; it was a fundamentally more difficult process to control.
The Fluid Problem
In a non-submerged setup, dielectric fluid is delivered through upper and lower nozzles that spray deionized water around the wire entry and exit points. The goal was to achieve what machinists called an “umbrella”; a cone-shaped flow of deionized water that kept the spark zone wet while the workpiece sat exposed to air. Getting there required careful balancing of nozzle pressure and position, all at extremely low power settings.
If you got it wrong, you knew immediately. Red sparks — a visible sign that the discharge environment was breaking down due to inadequate flushing — would appear, followed quickly by wire breakage. Some operators wrapped neck strips around the machine head and held them in place with clothespins to help seal the nozzles against the workpiece. It worked, but it was a workaround that revealed a fundamental limitation of the process. The machine was fighting you at every step.
Thermal Instability
Beyond the flushing challenges, non-submerged machining created significant thermal management problems. With only the nozzle spray cooling the workpiece, heat distribution across the part was inconsistent. The area being cut might be adequately cooled, but adjacent areas of the workpiece were exposed to ambient air, creating temperature gradients that caused dimensional drift; particularly problematic on longer cuts or when holding tight tolerances.
In a submerged setup, the fluid surrounding the entire part acts as a thermal buffer, absorbing and distributing heat evenly. This consistency is one of the key reasons submerged machining can hold tighter tolerances with less operator intervention.
Constant Operator Attention
Non-submerged machining demanded presence. Operators had to monitor the umbrella effect continuously, watch spark color, manage power ramp-up carefully, and respond quickly when anything went wrong. Unattended operation, let alone lights-out machining, was essentially off the table. The process simply wasn’t stable enough to run without supervision.
Submerged machining changed the equation entirely. With the fluid environment already established before the cut begins, the machine can run at full power settings from the start, with far fewer interruptions, and less babysitting required.
Head-to-Head — Where Submerged Wins Every Time
The performance gap between submerged and non-submerged wire EDM shows up across every meaningful metric. Here’s how the two methods compare directly.
Comparison Overview
FactorNon-SubmergedSubmerged
Startup timeSlow — requires low-power ramp-up to establish umbrellaFast — full power from the start
Cycle timeLonger — conservative power settings throughoutShorter — higher power, more aggressive cutting
Surface finishInconsistent — flushing variability affects finish qualityConsistent — 7.5 Ra achievable with 1 rough + 7 skim passes
Cutting stabilityProne to wire breakage and spark instabilityStable spark environment throughout the operation
Thermal controlInconsistent — partial cooling creates dimensional driftEven — full immersion buffers heat across the entire part
Operator burdenHigh — continuous monitoring requiredLow — machine handles process autonomously
Lights-out capabilityNot viableFully supported
Job Run Time
The cycle time difference starts before the first spark even fires. In a non-submerged setup, reaching stable cutting conditions requires starting at minimal power and patiently waiting for the umbrella to form and the nozzles to seat properly. Power can only be increased gradually, and a wrong move means wire breakage and a restart.
Submerged machines skip all of that. The tank fills, the part is immersed, and the machine cuts at optimal power settings from the first pass. There’s no ramp-up, no umbrella to find, no spark color to monitor. That difference adds up significantly across a full production run, and compounds even further when reduced wire breakage and fewer interrupted cuts is factored in.
Surface Finish and Precision
Cutting consistency directly drives surface quality, and nothing creates consistency like full immersion. In a submerged environment, every pass of the wire happens in the same controlled fluid environment, with the same flushing effectiveness, the same thermal conditions, and the same spark characteristics. The result is predictable, repeatable surface finishes cut after cut.
On Sodick’s deionized water-based wire EDM machines, operators regularly achieve 7.5 Ra with a single rough cut followed by up to seven skim passes — smooth enough that, at the right angle in the light, you can see a reflection in the part surface. Non-submerged machining, by contrast, introduces variables into every pass: localized flushing variations, temperature differentials, and spark instability that all leave their mark on the finished surface.
Cutting Consistency and Stability
Wire breakage is the single biggest source of unplanned downtime in wire EDM. On non-submerged machines, the conditions that cause wire breakage — inadequate flushing, unstable spark environment, thermal stress on the wire — are baked into the process. Even experienced operators couldn’t eliminate them entirely, only manage them.
Submerged machining dramatically reduces breakage frequency. The wire cuts through a consistent fluid environment on every pass, with reliable flushing and controlled spark intensity. Less breakage means less downtime, fewer resets, and lower risk of surface damage on nearly finished parts. It also results in fewer situations where secondary machining is needed to correct for inconsistencies introduced mid-cut.
Dielectric Oil — When Submerged Machining Needs to Go Further
Deionized water-based submerged machining covers the vast majority of wire EDM work. But for ultra-precision applications and micromachining, dielectric oil fluid unlocks a level of precision that deionized water simply can’t deliver.
Oil-based wire EDM is best understood as the next evolution of submerged machining rather than a separate method. The workpiece is still fully immersed. The process still relies on controlled electrical discharge. But, the dielectric properties of oil change the spark dynamics and make ultra-precision on the first pass possible.
Smaller Spark Gap, Finer Detail
The lower electrical conductivity of oil compared to deionized water creates a smaller discharge gap between the wire and workpiece. A smaller gap means the spark is more precisely localized, which translates directly into finer feature resolution and tighter dimensional control. For parts with intricate geometry, narrow slots, or microscopic features, this distinction is the difference between achievable and not achievable.
Sodick’s AP350L, for example, is purpose-built for fine wire micro machining with dielectric oil, achieving cutting accuracy down to 2 microns; the kind of tolerance that requires specialized measurement equipment just to verify.
Cobalt Depletion Eliminated
Machining carbide with deionized water dielectric causes a well-documented problem: the electrolytic reaction between deionized water and the cobalt binder in carbide gradually depletes cobalt from the workpiece surface, weakening the material and compromising part integrity. This is a critical limitation for tool and die shops working with carbide on a regular basis.
Dielectric oil eliminates this problem entirely. Without deionized water, there’s no electrolysis, no cobalt depletion, and no degradation of the carbide binder. The workpiece comes out with its material properties fully intact — a non-negotiable requirement for high-performance tooling applications.
Ideal for Medical Device Components
Medical device manufacturing represents one of the most demanding application environments in precision machining. Components are often microscopic, features are intricate, tolerances are measured in microns, and there is no margin for error on parts destined for surgical or implantable use.
Dielectric oil submerged wire EDM is built for exactly this work. The smaller spark gap enables feature resolution that deionized water-based machines can’t match. The stable, controlled cutting environment produces the surface consistency that medical manufacturing requires. And because oil doesn’t corrode metal the way deionized water does, finished parts can remain in the tank for extended periods without any risk of surface degradation — critical for shops running lights-out operations where parts may sit overnight before retrieval.
Lights-Out Machining Without Corrosion Risk
With deionized water dielectric, finished parts need to come out of the tank promptly after machining completes. Deionized water causes corrosion on ferrous materials, and leaving a part submerged after the cut is finished risks surface damage that can compromise part quality or require additional finishing.
Oil carries no such risk. A carbide workpiece can remain in an dielectric oil tank for extended periods, nights, weekends, however long, without any corrosion concern. For shops that run unattended overnight shifts, this isn’t a minor convenience. It’s a meaningful operational advantage that expands what lights-out machining can realistically accomplish.
Eco-Cut O: Oil Speed Without the Oil Penalty
One of the historical trade-offs with dielectric oil has been speed. Oil-based machines have traditionally cut slower than deionized water-based machines; a worthwhile trade-off for ultra-precision work, but a real limitation in high-production environments.
Sodick’s Eco-Cut O technology, available on the AP250L, directly addresses this trade-off. Eco-Cut O achieves the surface finish and precision advantages of dielectric oil while cutting up to 12% faster than deionized water dielectric and up to 25% faster than conventional dielectric oil. It speeds up the cutting process by reaching the required accuracy and surface finish in fewer passes — delivering oil-quality results without the penalty of traditional speed.
Sodick Technology Built for Submerged Performance
Whether you’re running deionized water or dielectric oil, Sodick’s wire EDM platform is engineered to extract maximum performance from a fully submerged process.
Tanque de trabajo de subida/bajada de 3 lados automatically adjusts fluid level based on workpiece thickness, eliminating manual fluid management between jobs. The no-drip design keeps the shop floor clean, and the tank can pause at intermediate positions to check progress on thinner workpieces without a full drain.
Fixed Jet Automatic Wire Threader (FJ AWT) supports both submerged and non-submerged threading. Thermal wire cutting produces a straighter wire tip, and the deionized water-jet function improves threading reliability — getting the machine back in cut faster after breaks.
Tecnología iGroove — Sodick’s patented wire rotation system — improves surface quality and accuracy while reducing wire consumption by up to 39%. In high-production environments, that’s a direct reduction in operating cost.
Compromiso térmico (TH COM) monitors the temperature of every machine component and compensates in real time, minimizing dimensional variation caused by ambient temperature changes or extended high-speed operation.
All of this runs on Sodick’s flat rigid linear motor drives — no belts, no ball screws, no backlash — backed by the industry’s only 10-Year Positioning Accuracy Guarantee. Tolerances of ±.0001″ are held reliably, year after year, across the full service life of the machine.
The Bottom Line
Non-submerged wire EDM had its era. For the operators who mastered it, it was a legitimate skill. However, the industry evolved, and the machines that replaced it weren’t just incrementally better, they were a different class of process entirely. Submerged machining delivers faster cycle times, better surface finishes, more consistent cuts, and dramatically lower operator burden.
And, for the applications that push beyond the capabilities of deionized water dielectric, oil-based submerged wire EDM, particularly with Eco-Cut O technology, opens up a tier of precision that was previously unattainable for most. Micro-components, carbide tooling, medical device parts measured in microns: this is where the industry is heading, and Sodick is leading the charge, spearheading this next evolution.Whether you’re evaluating your first wire EDM machine or looking to upgrade, connect with a Sodick expert today to find out which machine fits your operation.
