- Single ytterbium fiber laser, single mode infrared
- 60 micron laser spot diameter on focus
- Layer thickness from 20 to 80 microns
- Cylindrical build area, Ø7.87″ x 7.87″ (Ø200 x 200 mm)
- Bidirectional recoater that spreads layers in both directions to speed up each pass
- Open Parameters architecture with full control of laser power, scan strategy, and layer thickness
- AI assistant built into the machine interface that suggests parameter adjustments as the build runs
- Predictive maintenance and anomaly detection
- Remote connectivity and monitoring from desktop or mobile
- Oxygen monitoring below 100 ppm (0.01%)
- Nitrogen or argon shielding gas
- Single-phase 220 V power supply
- Materialise Magics CAM software
- Laser power configurations: 200 W, 300 W, or 500 W
- Tailored process parameter development
- Powder supply and qualification support
- Operator and engineering training
- Application and design support
| Build Area | Ø7.87" (Ø200 mm) |
| Build Height | 7.87" (200 mm) |
| Laser Type | Ytterbium fiber, single mode infrared |
| Laser Power | 200 W / 300 W / 500 W |
| Laser Spot Diameter | 60 microns (on focus) |
| Layer Thickness | 20 to 80 microns |
| Build Rate | Up to 50 cm³/h |
| Oxygen Monitoring | Below 100 ppm (0.01%) |
| Shielding Gas | Nitrogen, argon |
| Power Supply | 220 V / 32 A / 50 Hz |
| Dimensiones de la máquina | 43.31" x 23.62" x 70.87" (1,100 x 600 x 1,800 mm) |
| Peso de la máquina | 1.500 kg (3.307 lbs) |
| CAM Software | Materialise Magics |
- Steel alloys
- Aluminum alloys
- Nickel alloys
- Titanium alloys
- Cobalt-chrome alloys
Take a qualified material into production
The Sharp 200 runs the same 60 micron laser spot and 20 to 80 micron layer range as the Sharp 100, in a build area more than three times the working volume.
Your process, your intellectual property
Open Parameters puts laser power, scan strategy, and layer thickness in your engineers’ hands. Qualify an alloy nobody has published parameters for, tune a proprietary powder blend, and own the recipe that comes out of it.
How the AltForm Print Sharp 200 compares
CaracterÃsticas | AltForm Print Sharp 200 | AltForm Print Genius 200 | Other Metal 3D Printers |
Build area | Ø7.87" (Ø200 mm) | Ø7.87" (Ø200 mm) | Varies |
Build height | 7.87" (200 mm) | 7.87" (200 mm) | Varies |
Lasers | Single | Dual, 100% overlap | Single |
Laser spot diameter | 60 microns | 60 microns | Typically 70 to 100 microns |
Minimum layer thickness | 20 microns | 20 microns | Typically 30 microns |
Seams between laser zones | |||
Process parameters | |||
AI-assisted operation | |||
Best For | Material qualification, prototyping, and batches where build time is not the constraint | The same work at faster production speeds when throughput is key | General prototyping |
