- Four ytterbium fiber lasers, single mode infrared, up to 1000 W each
- 100% laser overlap, all four lasers reach the entire build area
- Dynamic load balancing across all four lasers during the build
- 80 micron laser spot diameter on focus
- Layer thickness from 20 to 120 microns
- Rectangular build area, 16.54″ x 16.54″ x 17.72″ (420 x 420 x 450 mm)
- Removable working chamber with automatic extraction
- Gas-tight filtration with automatic backflushing and full passivation for 24/7 operation
- Blockchain-based build certification for verified part history
- Fleet management across every connected machine
- Open Parameters architecture, with the option to lock a validated process for production
- AI assistant built into the machine interface that suggests parameter adjustments as the build runs
- Predictive maintenance and anomaly detection
- Remote connectivity and monitoring from desktop or mobile
- Oxygen monitoring below 100 ppm (0.01%)
- Nitrogen or argon shielding gas
- Materialise Magics
- XL configuration, extending build height to 39.37″ (1,000 mm). Needs roughly 13 feet of vertical clearance and a site review before order.
- Laser power configurations: 500 W, 700 W, or 1000 W per laser
- Beam shaping, available on request
- Powder handling from manual through fully automated closed loop
- Robotic part handling and production line integration
- Tailored process parameter development
- Powder supply and qualification support
- Operator and engineering training
- Application and design support
| Build Area | 16.54" x 16.54" (420 x 420 mm) |
| Build Height, standard | 17.72" (450 mm) |
| Build Height, XL | 39.37" (1,000 mm) |
| Working Chamber | Removable, automatic extraction |
| Laser Type | 4 x ytterbium fiber, single mode infrared |
| Laser Power | 500 W / 700 W / 1000 W per laser |
| Laser Overlap | 100%, full build area |
| Laser Spot Diameter | 80 microns (on focus), beam shaping available on request |
| Layer Thickness | 20 to 120 microns |
| Build Rate | Up to 4 x 100 cm³/h |
| Oxygen Monitoring | Below 100 ppm (0.01%) |
| Shielding Gas | Nitrogen, argon |
| Power Supply | 480 V / 60 Hz / 25kW / 27A |
| Machine Dimensions, standard | 153.54" x 82.68" x 98.43" (3,900 x 2,100 x 2,500 mm) |
| Machine Dimensions, XL | 153.54" x 82.68" x 153.54" (3,900 x 2,100 x 3,900 mm) |
| Machine Weight, standard | 6.000 kg (13.228 lbs) |
| Machine Weight, XL | 8.000 kg (17.637 libras) |
| CAM Software | Materialise Magics |
- Steel alloys
- Aluminum alloys
- Nickel alloys
- Titanium alloys
- Cobalt-chrome alloys
Your largest parts at your highest volume
This is the one machine in the range that pairs the full 16.54 inch envelope with four lasers. Build your largest components at up to 400 cubic centimeters an hour, on a plate that goes to 39.37 inches tall with the XL configuration.
Bring outsourced parts back in-house
Large components sourced from a casting house or a specialty supplier arrive on someone else’s schedule. Producing them yourself puts the lead time, the revision cycle, and the quality record inside your own building, which matters most on the parts you currently wait longest for.
Keep expensive powder in circulation
Fully automated closed-loop powder handling collects, sieves, and returns unfused powder to the supply, so material that never became part of a build goes back into the next one.
How the AltForm Print Brilliance 400 compares
CaracterÃsticas | Brilliance 400, standard | Brilliance 400 XL | Other Large-Format Metal 3D Printers |
Build area | 16.54" x 16.54" | 16.54" x 16.54" | Varies |
Build height | 17.72" (450 mm) | 39.37" (1,000 mm) | Rarely above 20" |
Lasers | Four, 100% overlap | Four, 100% overlap | Varies |
Build rate | Up to 4 x 100 cm³/h | Up to 4 x 100 cm³/h | Varies |
Machine height | 98.43" (8' 2") | 153.54" (12' 10") | Varies |
Vertical clearance needed | Standard bay | Roughly 13 feet | Varies |
Machine weight | 13,228 lbs | 17,637 lbs | Varies |
Laser spot diameter | 80 microns | 80 microns | Typically 100 microns and up |
Zone seams in the finished part | |||
Verified build record | |||
Process parameters | |||
Best For | Large components at high volume, in a standard bay | The same, plus parts that need real height | General large-format production |
