Every mold and die shop faces the same challenge: reducing machining time without sacrificing surface finish quality. Traditionally, improving one has meant compromising the other. With the right machine and a matched tooling and machining strategy, shops can achieve both, producing superior finishes in less time and, in some cases, eliminating polishing altogether.
This guide covers the machine parameters, capabilities, and workflow decisions that make secondary polishing optional on mold and die work. Here are the choices that determine whether your parts hit spec at the machine or end up at the polishing bench.
- Secondary polishing is avoidable on most mold and die work with the right machine tool. By combining surface finishing with your high-speed milling process, you eliminate an entire step in production.
- The Sodick HSM combines rough and finish milling in a single operating mode. A dual-chiller cooling system manages thermal expansion across long runs, keeping Ra values consistent from the first workpiece to the last. Separate passes and repositioning error disappear.
- Surface finish in high-speed milling is controlled by spindle speed and depth of cut. Higher RPM with smaller-diameter tooling at finer cutting depths reduces chip load to mirror-quality levels. The finish comes from the cut itself.
The sections below cover how Sodick’s HSM technology delivers those results and where it fits in a complete mold and die workflow.
How Sodick HSM Delivers Fine Surface Finishes in a Single Setup
Sodick’s UX Series High-Speed Mills differ from conventional VMCs in a key way: they combine rough and finish milling in a single operating mode. A small-diameter tool traverses at high speed and very fine cutting depths, so the surface comes off closer to final spec without the repositioning error and setup time separate passes introduce.
Three machine features make this consistent. Flat rigid linear motor drives produce 1G acceleration with near-zero backlash, and a dual-chiller cooling system manages thermal expansion across long runs. Without that stability, Ra values shift between the first workpiece and the tenth. The spindle spans 6,000 to 40,000 RPM (with an option for 60,000 RPM); at the high end with fine depth of cut, chip load drops substantially, driving finer surface finish.
The UX Series also integrates jig grinding without requiring a separate machine. For hardened steel inserts or components that need grinding-quality finish before qualification, keeping the workpiece in the same footprint preserves the dimensional accuracy established during milling.
When to Use HSM, When to Use a Wire EDM Machine, and When to Use Both
Most mold and die parts require two types of machining: 3D contours and cavities that need multi-axis milling, and 2D profiles (through-slots, punches, die openings) that need extremely fine surface finish with no mechanical contact. That second category is where wire EDM comes in, using electrical discharge to cut through-profiles with zero cutting force and tight tolerances.
Geometry drives the decision. Use HSM for 3D cavities, complex contours, and hard milling where the geometry requires multi-axis movement. Use a wire EDM machine for 2D profiles, through-features, punches, and die openings where extreme surface finish and dimensional accuracy are the priorities. Use both in sequence for mold and die work, which almost always includes both types of geometry.
In a combined workflow, the HSM machines the 3D cavity to near-net shape with a fine milled surface, and the wire EDM machine handles the 2D profiles with precision discharge finishing. Together, they cover the full part with minimal polishing required, because each machine delivers its respective surface finish spec from the cut itself.
This workflow depends on positional accuracy holding over time. Sodick backs all Wire EDMs with a 10 años de garantía de precisión de posicionamiento on the flat rigid linear motor drives. With these zero-friction magnetic drives, accuracy stays consistent through years of intensive use. The tolerance you program in year one will remain the same tolerance you achieve in year ten.
Better Surface Finishes Start at the Machine
Polishing adds a direct cost to every part in the queue. Every hour your machinists spend refining a surface by hand is an hour that could go toward programming, setup, or the next job. Mirror finishes in a single machining run are achievable when the right technology, parameters, and workflow are in place.
Connect with a Sodick expert to review your surface finish workflow. We’ll help you identify which Sodick HSM configuration matches your surface finish targets and where wire EDM fits into the workflow.
