K3BL
The K3BL is a high-precision small hole driller that delivers our widest machining range, spanning from 80 microns to 0.12”.
X-Travel: 11.81″ (300 mm)
Y-Travel: 7.87″ (200 mm)
Z-Travel: 11.81″ (300 mm)
The K3BL is Sodick’s most versatile small hole EDM. It handles the widest electrode range of any machine in the K Series, from ultra-fine micro holes up to larger diameter drilling, so shops can take on more applications without additional equipment. Powered by Sodick’s rigid linear motor and the LN Assist control system, it delivers consistent precision across long production runs with automation options that keep the machine running with minimal operator involvement.
  • Linear Motor Drive (Z-Axis Standard)
  • LN Assist Automated Programming System (Standard)
  • Ceramic Work Table
  • 18 Automatic Tool Changer (ATC)
  • 15 ATC + Automatic Electrode Feeder (AEF)
  • Rotary Table
  • Signal Tower Type 3
  • UPS (Uninterruptible Power Supply)
X-Axis Travel 11.81"
Y-Axis Travel 7.87"
Z-Axis Travel 11.81"
W-Axis Travel 9.84″
Diámetro del electrodo ø.003″ ~ .118″
Tamaño de la mesa de trabajo 23.62″ × 11.81″
Distance from Guide to Table 2.36″ ~ 12.20″
Dimensiones de la máquina 44.49″ × 64.76″ × 94.69″
Maximum Workpiece Weight 661.4 lbs
Peso de la máquina 3,306.9 lbs
Presión atmosférica 0.5 ~ 0.6 MPa
Total power input 3 phase 200/220V, 0.75 kW
Dielectric Fluid VITOL-V2 (oil-based)
Dielectric Tank Capacity 64.72 gallon
Motor lineal Standard on Z Axis
Automatización ATC 18 / AEF + ATC 15
Asistencia LN Standard Feature
Rotary Table Available as an Option
Sodick’s rigid linear motor comes standard on the Z-axis of every K3BL. Unlike conventional ball screw drives, there are no mechanical parts wearing against each other, so accuracy remains consistent and maintenance stays minimal. The result is a machine that performs the same on day one as it does years down the line.
The K3BL covers a wider electrode range than any Small Hole EDM Sodick has ever built. From micro hole work at the finest tolerances to larger diameter drilling, it handles applications that would previously have required two separate machines. That means more flexibility and space for your shop floor.
The 18-position ATC changes electrodes automatically during cutting, so production keeps moving without an operator present.
The ceramic table provides high insulation, keeping electrical discharge energy focused exactly where it needs to be. It also runs cooler and lighter than cast iron, which reduces wear over time.
Muestras
Micro-Hole, 200 Holes ø.00217″
Workpiece MaterialWC/G5
Workpiece Thickness.0197″
Electrode MaterialTungsten Rod ø.00118″
DielectricOil
Hole DiameterIn .00217″–.00244″ , Out .00228″–.00256″
Cutting Time2–5 min/hole
Machine ToolK3BL
Micro-Hole, 10 Holes ø.00146″ (ø.037 mm)
Workpiece Thickness.0118″
Electrode MaterialTungsten Rod ø.00079″
DielectricOil
Hole DiameterIn .00146″–.00150″, Out .00150″–.00157″
Cutting Time6–8 min/hole
Machine ToolK3BL
